Shifter popped out of lug on fork
Scott Daniels
09-04-2004 19:57:11
I got my shifter assembly out at last, I found out what happened. It appears that when it was in reverse (which is in-between the 1/4 and 2/3 forks, and I tried to put it in neutral, the shift lever "pin" popped out behind the reverse lug and was in "no mans land" betweeen the other two forks. Everything in the assembly appears to be in reasonable condition. What could be worn which would allow the shift lever to pop out of the lug like that? It appears that nothing was damaged, but I think I ought to replace whatever might be worn to prevent it from happening again.
On related subject, the teeth on the gear bushings are quite worn, and so the tractor pops out of 2nd & 3rd gear a lot. I read that it was due to this wear. I was wondering if it might also be related to possible wear to the bearings or indents in the shifter rods? Since they are responsible for locking the shift forks in the correct possition, I was thinking any wear to them might also lead to it popping out of gear. What are y'alls thoughts?
Thanks so much for all the great help!
Scott
