Front engine seal and carburator
Rick Hester
05-28-1999 09:56:13
I just bought a 1950 A-C Mod. B. This is my first old tractor so I will be looking for alot of pointers. I have ordered the operator's manual, service manual and parts manual.
The first two problems that I must address are what appears to be a leaking front engine seal and a leaking carburator. How much trouble is it to replace the front seal and and rebuild the carburator?
Any hints would be appreciated.
Aaron
06-22-1999 10:21:45
 Re: Front engine seal and carburator in reply to Rick Hester, 05-28-1999 09:56:13
I just replaced the front seal on my B this spring. I use it to mow about 4 acres with a woods 5' deck. The hardest part about replacing the seal is getting to it since you have to remove the front axle mounting plate. I placed a 'speedy sleeve' over the end of the crank for the new seal to ride on. I was able to find all of the parts at my local NAPA. Good luck.
Charlie Okla
05-28-1999 22:04:04
The float may be bad in the carb. I find this to be a very common problem in old carbs. Other than that it is easy. Setting the fuel level in the carb if you have to patch the float is a pain in the wazoo. You can't use the normal setting method.
