Generator
David Craig
09-02-2004 10:48:15
My generator will not charge my battery.It has been rebuilt and checked.Can someone help me.
Thanks
steve(ill)
09-02-2004 16:02:57
 Re: Generator in reply to David Craig, 09-02-2004 10:48:15
if it is 6 volt, you have a cutout relay on the side of the generator and the light swith is the "ground" for the "F" on the gnerator.--- if you have a 12 volt system you have a voltage regulator somewhere and the "A" and "F" terminals on the generator go to the regulator. first, ground the "F" terminal on the generator to the tractor frame and see if that helps. if so, check your regulator and regulator ground or the light switch wires and grounding of the light switch case. if that done work, supply more info.
