help my wd 45 diesel cooling system is all screwed
justinfrommcdonough
09-01-2004 14:18:29
i have a allis chalmers wd 45 diesel and the other day i noticed it was overheating around 230deg so i took out the thermostat. today alot of radiator colannt was coming out the over flow tube, but now when i have the cap of the radiator and i go to start it radiator fluid shoots 12 feet in the air. the oil has none whatsoever cooling fluid in it and the exhaust is prefectly normal, so im not leaning to a bad head gasket im puzzeled possibly this buda engine needs a thermostate hopefully ope some one has had a very similar problem and that they can help me thanks all.
JRA
09-02-2004 23:42:30
 Re: help my wd 45 diesel cooling system is all scr in reply to justinfrommcdonough, 09-01-2004 14:18:29
sounds like you are getting compression in to the cooling system somewhere.
justin from mcdonough
09-04-2004 17:43:53
 Re: help my wd 45 diesel cooling system is all scr in reply to JRA, 09-02-2004 23:42:30
yah jra got the head ofg now and gona replace the gaskets no signs of pressure past the gasket but with only 15 psi probaly blowin by hard to see it in the gasket where it went bad i think when the rebuilt my motor they used a cresent wrench to tourqe the head down what do u think?
