WD Lights, Halogen on Magneto ?
Joe - Wi
08-31-2004 17:34:56
Hello Guys,
I have a question about lights on our WD Allis. Can I install Halogen Lights on our WD that has a 6 volt system w/Magneto ?
The current lights are not very good at all, and the extra light from Halogens would be ideal.
Glen in TX
09-03-2004 16:25:10
 Re: WD Lights, Halogen on Magneto ? in reply to Joe - Wi, 08-31-2004 17:34:56
My Q Beam handheld rechargeable spot light uses a 6V halogen bulb but it isn"t the sealed beam type and is the small insert type with wire on it. Can get those bulbs at walmart. Only 6v halogen I"ve ever seen. Like Steve says though your charging system isn"t going to keep up with 2 or 3 of those though. Not enough amperage output on a 6V generator.
Steve in N.J.
08-31-2004 20:33:07
Joe,
Unfortunetely, there isn't a 6V halogen lamp available that I know of. I would think you would have to convert to a 12V system with a little bit higher amp Alternator. Halogen lamps steal some serious power to operate, so you would need a good reliable charging system, and the ole' 6V system with generator won't cut it. We offer a conversion to 12V if you consider changing over. Drop us a line if interested. Be more than happy to help ya out....
Steve/B&B Custom Circuits
old
08-31-2004 19:29:25
Yes you can if you can find 6 volt ones but I've never seen them
