WD45 Low Oil Pressure when hot
Tim E
08-29-2004 11:19:48
I have a WD45 that has very good oil pressure when first starts "a" in Normal on a new guage. When the engine reaches operating temp, the oil pressure falls to where it barely registers even at full throttle.
I have read through the message lists. The oil filter is a Hastings LF405. I have shimed the oil pressure relief valve a bit.
I assume that I am dealing with worn bearings. Would anyone have any other ideas or suggestions?
Playfarmer
08-30-2004 14:09:07
 Re: WD45 Low Oil Pressure when hot in reply to Tim E, 08-29-2004 11:19:48
You said a new gauge. Is it one made for the WD series. They only need 12 pounds to be normal. Many new gauges need around 30 piunds to read normal. Just my two cents
Sundance
08-30-2004 19:16:59
 Re: WD45 Low Oil Pressure when hot in reply to Playfarmer, 08-30-2004 14:09:07
You can drop heavier oil into the crankcase if you like, ND 40w, however after 25 years of repairing engines I can tell you that you more than likely need to replace some bearings , mainly crank. Before you do that hook an oil pressure gauge directly to the engine and read the pressure directly off the block and forget reading the funny "gauge" on the cluster.
Tim E
08-31-2004 13:58:35
 Re: WD45 Low Oil Pressure when hot in reply to Sundance, 08-30-2004 19:16:59
I appreciate all of the helpful comments and suggestions that I have received in the past couple of days regarding the WD45 oil pressure.
I am particularly interested in the idea of using a standard oil gauge that reads in PSI rather than "Normal". Now further expressing my ignorance, Is there a place on the WD-45 block that I can read oil pressure directly?
R.k.
08-29-2004 20:08:49
Had a 45 with low oil pressure ,took off valve cover and the oil pipe lubricating the rocker arms broke into ,repaired it and presure went back to normal.
Phil H Munson
08-29-2004 19:49:05
If memory serves me right, and once in a while it does, the oil pressure, at operating temperature, should be between the o and r in the normal word. Shimming the relief spring may help develop leakages, with the excessive pressure, particularly with the main seals on the crank. After a bijillion or so hours, even a good tractor may need some new bearings or other help.
Aaron SEIA
08-29-2004 15:49:35
One other thing to look at if/when you do a major teardown is the camshaft bushings. The camshaft is the main oil galley for the W series engines. Oil goes first to the cam, which is hollow, then out to the main and rod bearings. If those bushings are shot, oil won't even get to the main and rod bearings. Also, make sure that your oil filter has the cotton stuffing in it and not the new style paper element. Heavier oil will help for now, but I'm thinking you need a new set of rod/mains and cam bushings.
Aaron SEIA
DanD.
08-29-2004 11:41:14
What viscocity oil are you using? A 15W-40 diesel oil might maintain a higher viscocity at higher temps.
Tim E.
08-29-2004 12:39:27
 Re: WD45 Low Oil Pressure when hot in reply to DanD., 08-29-2004 11:41:14
Thanks.
I was using 10W-30, but switched to SAE 40 before the last use. Once the tractor reached operating temp, it still dropped to barely readable on the guage.
