WC Starting Problem, Which Cylinder is #1???
Pop'n Johnny
08-29-2004 08:42:47
I posted a topic on this starting problem I"ve been having, and decided to check the timing one last time. I want to make sure of what I"m doing so heres the question. How are the cylinders numbered. I"m setting the timing using the front cylinder as the #1 cylinder and using the "F" mark on the flywheel looking through the little port opening on top of the bell housing. This is right?
DanD.
08-29-2004 11:54:18
 Re: WC Starting Problem, Which Cylinder is #1??? in reply to Pop'n Johnny, 08-29-2004 08:42:47
I believe you look through the bottom of the bell housing. However, on these old magneto tractors, I don"t use the timing marks at all. Remove all the spark plugs and have someone turn the engine over slowly with the hand crank while holding your thumb over #1 (front) spark plug hole. When the air is being forced out past your thumb, you know that #1 is the next to fire. Remove the two screws holding on the distributor cap, remove the cap, and you should see the rotor pointing toward the upper terminal toward the block. If not, remove the two bolts holding the magneto to the tractor, pull it off and turn the magneto until the rotor is pointing properly. Reinstall the magneto, the cap, and install wires in a clockwise direction looking forward toward the cap. The order is 1243. You can see that the holes are slotted that the bolts go through that hold the magneto to the tractor. Put them about in the middle. Start the tractor and loosen the bolts and turn the magneto back and forth until it runs the most free wide open. That"s all you need to do for timing. Please let us know how it turns out.
Pop'n Johnny
08-30-2004 16:00:13
 Re: WC Starting Problem, Which Cylinder is #1??? in reply to DanD., 08-29-2004 11:54:18
Thanks, Dan. I"ll give it a shot.
Jon.
