Model B 6 volt
Tom H
08-29-2004 05:08:37
Does anyone know if they make a battery tender for a positive ground 6 volt battery. Correct me if I am wrong , but doesn't the B have a positive ground system and does the battery tender have to account for this? Where can I find one? Thanks for your help in advance.
steve(ill)
08-29-2004 06:00:51
 Re: Model B 6 volt in reply to Tom H, 08-29-2004 05:08:37
the B was 6 volt positive ground from the factory. some have been changed to negative ground, some to 12 volt. check your battery terminal to see which is grounded.----- the battery charger should be a 6 volt unit to charge 6 volt. it dont care what is grounded, just put the negative lead on the negative terminal of battery, etc.
