b year?
Eric
08-29-2004 01:26:50
i bought an aliis chalmers b tractor and cant figure out what year it is above the shift lever on the trans case it says B8 038
steve(ill)
08-29-2004 06:05:50
 Re: b year? in reply to Eric, 08-29-2004 01:26:50
if it is 8000 it is a 1938 and would have hand brakes. front wheel rims may have the hub (bearing housing) built into the big center disc, with the rim being just a ring. probably does not have an electric start, probably no generator or battery.----- - most of these things came after 1940.--- if you are missing a digit and it is 80000 then it is a 1948 and would have all the above.
Eric
08-29-2004 14:31:16
 Re: b year? in reply to steve(ill), 08-29-2004 06:05:50
thanks , it does have elect start and has been converted to 12 volts
