WD-45 oil mixing
Guyzoo
08-28-2004 08:53:05
Hi, I have a Wd-45 and I think there is hydraulic oil that goes in the trans and differential. What can cause this and how to fix it? if it is a oil seal can you tell me how to remove the torque tube. If this help I have the engine removed so it is probably the good time to fix this
bw in mo
08-28-2004 19:31:32
 Re: WD-45 oil mixing in reply to Guyzoo, 08-28-2004 08:53:05
It is an oil seal,I have not replaced one so I would proble mess you up on how to do it. When I was on the farm ours leaked to trans. but never fixed the seal , it will only get to the level of the hyd oil level. Run them that way for years with no trouble.
