WD or WD45? you tell me
mike fenner
08-27-2004 21:25:27
I have a tractor I need to identify. It was represented as a WD, the serial numbers are rough and hard to read. Anyway, near as I can tell it is a '50 model. However, it has a hand clutch, my neighbor tells me he doesn't believe the WD ever had a hand clutch. Somebody tell me. Thanks
wdTom
08-30-2004 18:13:18
 Re: WD or WD45? you tell me in reply to mike fenner, 08-27-2004 21:25:27
There are many other differences of which I will list a few I can remember. On a 45 the seat suppoet is curved and has an adjustable spring/shock positon at the top of the shock, WD is a straight seat support with one sharp bend at the top near the seat, no adjustable mount shock. Air filter on the 45 has a larger air passage where it passes the exhaust manifold, is straight here, WD is cruved to pass manifold. Later tractprs had stamped steel foot clutch foot pad as opposed to cast, and a stamped steel steering shaft support at the frame rail in the oil filter area. Would have to read my parts manual to remember other differences.
J.C. IN AZ.
08-29-2004 15:30:52
WD has a straight Gear Shift and the Wd45 has one with a bend to the right. WD had no Factory Power Steering while both my WD45's had Factory Power Steering. I put an Charlyn Power Steering on my WD which I had a loader on. The WD had a Plate 4"x14" aprox. on the right side of the Engine Block to access the Valve Push Rods while the WD45 did not.I can't remember if the Wd had a Steering bolster in the front that was adaptable for a Wide Axle but I don't think it was whereas the WD45 was adaptable to a narrow front or a Wide Front axle.Regardless my WD had a narrow Front and both WD45's had Wide front Axles.I Farmed in the 60's@70's and mainly Row cropped with a D17 and a 190XT while the 45's were Wagon Tractors and the WD was used for Loader work.I was a good Customer of Hextell Imp. of Serena Ill. long out of buisness now. Hope this helps. John
DanD.
09-01-2004 05:44:59
 Re: WD or WD45? you tell me in reply to J.C. IN AZ., 08-29-2004 15:30:52
While the WD45"s all have the curved shifter, the last year or so of WD production also had the curved shifter. So, if the shifting lever is straight..it"s a WD for sure. If it"s curved...could be either. It"s a common mistake for people to assume that a curved shifting lever automatically means it"s a WD45.
Gene
08-27-2004 21:48:37
WDs have a hand clutch. Take a wire brush to the serial numbers.
Right side of the WD engine will have a large plate behind the oil filter. WD45 doesn't. But that doesn't mean that the engines haven't been changed.
There will be other responses with more differences.
DanD.
08-27-2004 21:43:46
All WD"s had the hand operated transmission clutch to give live hydraulics and PTO just like the WD45. Does your tractor have a straight or curved shifting lever? Is there a large steel plate bolted on the right side of the block or is it just the cast iron block all in one piece? Look at the engine serial number stamped in the block near the carburetor. Does it begin with a "W" or with a "45"?
Chuckstr
08-28-2004 05:12:22
 Re: WD or WD45? you tell me in reply to DanD., 08-27-2004 21:43:46
just for your information the later WDs had the curved shifter. I own one its a 53 model
