Allis -Chalmers 1958 D17
Richard
08-27-2004 09:19:06
I am trying to get the wheels off my tractor to have them sandblasted in preparation for new tubes and tires. Is there a trick to getting them off after taking the lug nuts off? I'm not sure if it's because they've been on so long, or what I am looking at in the center is holding them on. Thanks for any help.
kevin k
08-29-2004 20:39:04
 Re: Allis -Chalmers 1958 D17 in reply to Richard, 08-27-2004 09:19:06
what works great for that is if you have access to a pressure washer with hot water ability, from the outside spray the hot water to the center of the axle and wheel until its hot. a couple good raps with a sledge and it will pop off.
Kevin (FL)
08-27-2004 18:32:54
Richard,
If you're talking about the front rims, once you get the lug bolts out, the rim should come off. If you looking at the square "nut" in the hub, that's just the dust cap for the bearings. A good hit with a 3 or 4 pound hammer and a piece of 4x4 on the rim should break it loose.
Can't help you if you're asking about the rears. Haven't had to take ours off yet. We have a '59 diesel.
Richard
08-27-2004 18:42:56
 Re: Allis -Chalmers 1958 D17 in reply to Kevin (FL), 08-27-2004 18:32:54
Yeah, it's the rear ones, and I have the tires off and can't try the advice by mojo on pulling forward and backing up. Thanks anyhow
mojo
08-27-2004 09:41:23
Thread the lugbolts back on but not completely, then pull foward and back to break them loose.
If I remember right their similar to a WD45. Sure someone will straighten me out if wrong.
Richard
08-27-2004 10:00:10
 Re: Allis -Chalmers 1958 D17 in reply to mojo, 08-27-2004 09:41:23
Thanks for the info, but I have it up on blocks with the tires off...
