B sickle mower
BC NC
08-25-2004 20:10:47
I recently got incredibly lucky and bought a B/C 6' belly-mount sickle mower for $100. The thing is low-time and even has 75% of the original paint on it. My problem is it was 95% complete. Everything is there but the drive pulley that mounts on the pto housing. Can someone tell me the diameter the pulley is supposed to be so I can have one fabricated, or does someone know here I can find an original? Any help would be greatly appreciated. Thanks.
Rod (NH)
08-26-2004 15:07:49
 Re: B sickle mower in reply to BC NC, 08-25-2004 20:10:47
Hi BC,
My B belly mower drive pulley is 10" outside diameter (actually more like 10-1/8"). I don't think you have to have a special one fabricated for big $$$. You could use a standard pulley from Browning. The belt is a "C" section belt -- I use a C51 belt from Gates. The browning pulleys use replaceable split taper bushings with different available bores. You would get the bushing to match your PTO shaft. That's either the 1-1/8" 6 spline or the 1-3/8" 6 spline depending on year. Such a pulley would obviously look different than original and would not have the adjustable pitch diameter feature. But if you are interested in function over appearance, that shouldn't make any difference. I use my mower every year to mow about 10 acres and have never (in 30 years) found the need to change the sickle speed by re-shiming the drive and driven pulleys. About any local dealer of power transmission equipment should be able to get you Browning stuff.
third party image Rod
BC NC
08-28-2004 18:57:47
 Re: B sickle mower in reply to Rod (NH), 08-26-2004 15:07:49
Thanks Rod! Your information is much appreciated.
