d17 AC
jimbob allis
08-25-2004 14:35:49
Have D17 AC 196?when operating on hillside wheels make a poping and cracking sound in gear housing. There is no loose motion in bearings. Any info will help ?Thanks Jimbob Allis.
tractor james
08-27-2004 14:13:33
 Re: d17 AC in reply to jimbob allis, 08-25-2004 14:35:49
Maybey you can break the locks loose and then retighten them and it will stay quiet
50WD
08-25-2004 17:11:28
My WD does that once in while when making a corner on a side hill. I think it is the spin out wheels moving around on the rails just a bit. Make sure all the cams are in the locked position.
JMS/MN
08-25-2004 22:02:14
 Re: d17 AC in reply to 50WD, 08-25-2004 17:11:28
I agree. Look for rub marks on the rails- even if you have the locks in place, there is some room to move. The cams develop a flat spot over time, once they start to slip. Also, you will see a flat spot on the rails. This does not fix itself- might need to remove the tires, and build up the rails with weld.
