B trans. fluid/oil
campbem
08-25-2004 08:15:47
The manual says to use 20W oil for transmission case. I don't believe I've seen 20W on the shelf.....doesn't mean its not there. Is this still the oil to use or is there a suitable substitute?
I'm going to be testing my hydraulic pump in the hopes of adding a 3pt conv. so it got me to thinking about oil.
Matt
DanD.
08-25-2004 13:25:58
 Re: B trans. fluid/oil in reply to campbem, 08-25-2004 08:15:47
There is #20 non detergent oil available but the best modern oil to use would be a universal trans/hydraulic oil. Works good for the hydraulics and also provides good protection for gears and bearings. Was no such think when the owners manual was printed that"s why it"s not mentioned.
steve(ill)
08-25-2004 16:16:36
 Re: B trans. fluid/oil in reply to DanD., 08-25-2004 13:25:58
you can get "universal hy trans" at Wal Mar or farm store for $10. for 8 quart pail. see spec AGCO 821 on the back.
campbem
08-25-2004 17:35:59
 Re: B trans. fluid/oil in reply to steve(ill), 08-25-2004 16:16:36
Do I need to do anything special to "clean out" the 20w oil from my trans case or just simply drain it out and refill with the univ. hy trans fluid?
Stupid question probably, but have to ask.....
Matt
steve(ill)
08-25-2004 20:51:10
 Re: B trans. fluid/oil in reply to campbem, 08-25-2004 17:35:59
the 20wt you have is either a hydraulic base or motor oil. either will mix fine with the hytrans. if you had 90 wt gear lube in it, i would run a few hours with the hytrans, then drain it out and refill with new.
