Torque converter gets warm
Joe
08-23-2004 20:21:52
Just installed a powersteering unit on our WD. It is a CharLynn torque converter with the powersteering pump and resevoir. We cut it all in and got it all working except that the torque converter in the steering shaft gets warm to the touch. We have the same unit on our SuperM and that can work for hours and the torque converter does not get warm. The WD can run for 2 minutes and the torque converter will get warm to almost hot to the touch. Is this usual? There are no odd noises or leaks and the steering is great. One handed steering on a 49 WD that 2 weeks ago needed a very strong large man to operate. Could it be that the power steering pump is not supplying enough oil/fluid to the pump. Can we run it this way or will the converter fail. We paid some good money for the whole unit so I dont want to ruin it. Any help would be great. Thanks ! - Joe
Dave Grubb
08-24-2004 18:33:03
 Re: Torque converter gets warm in reply to Joe, 08-23-2004 20:21:52
I have a CharLynn unit on my WD45 and use a Saginaw power steering pump. I was using the tractor this evening and checked the torque generator temperature. It was real warm but not hot to the palm of my hand. I put a thermometer in the pump fluid reservoir and the fluid was 105 to 110 degrees F. I don't think you have a problem, but you might keep a check on the fluid for color change or change of smell.
Joe
08-24-2004 19:09:03
 Re: Torque converter gets warm in reply to Dave Grubb, 08-24-2004 18:33:03
Thanks Dave,
I will check the resevoir temp this weekend. I am taking digital pictures of the installation and hope that I can figure out how to post it on this site with instructions for any one else who might be doing the same installation. I have used the archives and copied a lot of what you have done and printed a lot of helpful pictures. Thanks again - Joe
