Value of D-17
COL
08-23-2004 14:44:07
What is a D-17 Series III with a junky cab worth in Wisconsin? It has an after market 3 point. The front tires are poor and the rears are good. The paint is so-so.
COL
08-24-2004 17:48:09
 Re: Value of D-17 in reply to COL, 08-23-2004 14:44:07
The D-17 is a gas that runs quite well and has a wide front.
Jrry
08-24-2004 07:23:37
Machinery Link values the series III at $2551 in fair condition to $3,441 in good condition. I have not seen any under $2,000. However, I listed a D-15 LP wide front in good condition for $1750 and did not even get a question asked.
John (MO)
08-24-2004 06:13:01
D-17"s usually bring more than $1500 to $1800 in MO, even junky ones. The cab won"t add any value but I doubt it will take away much either. A series 3 with 3pt conversion that doesn"t have major engine or transmission issues, would most likely fetch $2500 to $3000 at most auctions around here. But then if 2 people really want it, stand back and watch out, it could go for more.
Kevin (FL)
08-24-2004 05:41:29
Assuming it runs and its a wide front end, my first guess would be $1200-$1500, not being able to see its condition and also hear it run. With so little information about the tractor, its hard to put a value on it. More info and a couple of photos would help determine a general value for it. It could be worth more than what I said--again, more info would be needed to do it justice....
