WD STUCK IN TWO GEARS
NEWTO ALLIS
08-23-2004 10:47:04
I am buying a wd that the shift lever won't move, the owner said it lockup up while moving snow, he was shifting really fast. I know this has been talked about before, but could a person jack it up and rock the rear wheels while some on wiggles the shift lever, or do you need to pull the shift lever off and pry things apart? Is there any tricks a person needs to know before doing this? What manual would you recommend I get to give me a good understanding of what parts I need to replace I don't want to have it stick in two gears when it's 4o below. Sorry for the long post I have to get it this upcomeing weekend. Thanks
mojo
08-24-2004 14:04:58
 Re: WD STUCK IN TWO GEARS in reply to NEWTO ALLIS, 08-23-2004 10:47:04
John(C-IL) is who I agree with. Mine did it regularly and you do get pretty good at it! Solved the problem by going to AGCO and getting a special dished washer and 3 spacers that set the shifter further into the case and kept it there. I only used 2 of the spacers.
JimE in NE IN
08-23-2004 20:57:14
OK NEWTO ALLIS-It took me a while to find the information but here goes. I (with help) rewelded my shifter on my WD-45. I took pictures and measurements and posted them on another web site. I would post it but Kim has guidelines I try to respect. If you would like the pictures I could email them to you. If you look at the pictures it will explain the measurements. 1/2" wide and 34/64 front to back and 1 7/64 in height The 1 7/64 is from the bottom of the tip to the flat just above the new weldment. The only problem I"ve had is with no pressure on 1st gear it will occasionally slip into neutral. I did polish it with a 80 grit dremel tip for my own piece of mind.
Ed Weber
08-24-2004 15:39:49
 Re: WD STUCK IN TWO GEARS in reply to JimE in NE IN, 08-23-2004 20:57:14
Hello Jim I have to weld up my WD45 shifter also. Would you please send me your pics.to my email [email protected] It will be much appreaciated. Thanks Ed
John (C-IL)
08-23-2004 15:49:15
It isn't necessary to pull the top off of the gear box. All that is really required is to remove the shifter, use a long screwdriver or a pry bar to align the shifting forks and replace the shifter. It takes a little practice, but after a while you can do it in less than 5 minutes. While the shifter is out, check the end that goes in the forks for wear, that is quite often the problem although there are several other pieces that wear and cause this problem.
Doug in OR
08-23-2004 12:07:31
Remove the top of the transmission, gearshift and all. It is not really a difficult job - I did this when I was a kid. Once the transmission is open, slide all the gears until they are all in the neutral position. After this, replace the transmission top - aligning the shifter (in neutral position) with the slots below. Shifting fast on a tractor with worn forks - and most old tractors have worn forks - is not a good idea. If you are careful, this problem may never happen again.
