Valve tappet clearance on a WD.
Pat Cruise
08-22-2004 19:58:54
What shoult the valve clearance be on a 1950 WD.Should they be set cold or hot?
Many thanks,
Pat
acorange
08-24-2004 15:18:53
 Re: Valve tappet clearance on a WD. in reply to Pat Cruise, 08-22-2004 19:58:54
Ditto's to bushhogpapa....
When filing or grinding have some water close by
to cool the rockers if they get to hot.
That way you won't lose the temper in the metal and they won't get "soft".
BushogPapa
08-22-2004 21:21:54
Set the tappets to .012" HOT...
Now, you will have to check to see if the rockers are worn at the valve-stem end.. If they are, be very careful adjusting them..or better yet...remove the rocker arm shaft and carefully grind or file the rocker arm tips level..matching the original contour... This way, you will get a real good setting, and it will sound like a "sewing Machine" again..!! Be SURE the engine is HOT..not "just warmed-up" Ron.
Chad from MI
08-23-2004 09:52:06
 Re: Valve tappet clearance on a WD. in reply to BushogPapa, 08-22-2004 21:21:54
What do you mean ground flat rocker arms? then you say follow the contour of the rockers? Which is it? flat or countour?
what is the best way of doing this? Ours needs to be fixed.
Chad
BushogPapa
08-23-2004 10:27:52
 Re: Valve tappet clearance on a WD. in reply to Chad from MI, 08-23-2004 09:52:06
Lock the rockers, one at a time, in a vise, and then you can carefully use a small grinder, or a good file to re-condition the tapet surface... I like to only grind the one side that does not hit the valve stem... If I do grind the sntire surface, I try to keep the rounded profile of the un-worn portion--just grind that side down until it will let you have a good level surface for the feeler gage to slide thru... By "level", I mean across the rocker arm, not length-wise.. You could even grind the un-worn portion down a little further, just to be sure there is no problem with interference with any un-worn portion.. Just keep a full contact area on the valve stem.. you may need to "dress" it with a fine file to get the final finish on it..and rounded contour. A grinder just makes the job go a lot faster..just don"t get carried away, using it..!! Ron..
