WD Questions:Oil pressure and valve tappet noise
Pat Cruise
08-22-2004 16:11:19
I have a 1950 WD with original engine and it has never been into internally.Question #1 How quickly after starting engine hot or cold should I be registering oil pressure,It takes about 15-20 seconds to register pressure and it climbs slowly.Once it does it reads just above the "R" in the middle of the guage.Should I stop using it right away and see what the problem is or is this normal for an engine this old?Will I damage it if I keep using it like this?Question#2 How much if any valve tappet noise should I be hearing and is tappet adjustment all thats needed to clear this up?The engine runs great at all speeds and even under load.Idle is a bit rough but the engine is not new and has never been into.Thanks for your suggestions!!!
Gene
08-22-2004 17:04:55
 Re: WD Questions:Oil pressure and valve tappet noi in reply to Pat Cruise, 08-22-2004 16:11:19
Oil pressure is normal. Supposed to read in the middle of the gage.
Valve tappet noise. You will have some. You might want to check the valve lash - adjust the tappets. That might reduce some of the noise. That's not a big job.
That engine should idle soooooth. If you haven't done so in a while - a tune up might solve the idle problem.
