AC 180 pumping hyd oil out from around gear shift
gwece
08-21-2004 08:15:24
HELP! A friend of mine has an AC 180 that all of a sudden starting pumping hydraulic oil out from around the transmission gear shift lever. Pumps the hydraulic oil out through the transmission reservior until all hydraulic power is lost. Oil is white and foamy. He drained all the oil from both hydraulic and transmission side and refilled with new oil. Went back to the field and in about 30 minutes it started doing the same thing again. Any advice is greatly appreciated.
crankshaft
08-21-2004 10:24:34
 Re: AC 180 pumping hyd oil out from around gear sh in reply to gwece, 08-21-2004 08:15:24
Tell David F the problem is he has a leak inside the transmission lines to the rear lift or seals leaking in the rear lift. I think
gwece
08-21-2004 20:16:41
 Re: AC 180 pumping hyd oil out from around gear sh in reply to crankshaft, 08-21-2004 10:24:34
How did you know it was David F. ?????
DanD.
08-21-2004 11:36:56
It wouldn"t be the rear lift because the 180 has external rams, unlike the earlier D series tractors.
