OVERHAUL GASKET KIT FOR WC --WHAT HAPPENED??
DON DIXON
05-26-1999 17:46:35
I purchased a overhaul gasket kit from Agro Allis to overhaul my 1946 WC. as I go along putting the thing back together I keep running into wrong gaskets, so far the rear main bearing seals have been wrong, the governor gasket is wrong, the exhaust manifold gaskets are wrong, and there was no gasket for the side plate that covers the valve pushrods.Has anyone else had any of these problems? MY DEALER SAYS IT IS A FIRST TIME FOR HIM,,HE THINKS THAT PERHAPS THE FELLOW AT THE FACTORY THAT ASSEMBLED THIS PARTICULAR SET WAS DRUNK.
Wd
05-30-1999 16:38:24
 Re: OVERHAUL GASKET KIT FOR WC --WHAT HAPPENED?? in reply to DON DIXON, 05-26-1999 17:46:35
Is the dealer going to order you another set? If so whats da problem man? stuff happens
DON DIXON
06-03-1999 15:51:41
 Re: Re: OVERHAUL GASKET KIT FOR WC --WHAT HAPPENED?? in reply to Wd, 05-30-1999 16:38:24
DA PROBLEM IS, THAT I DIDNT KNOW I NEEDED ANOTHER GASKET SET BECAUSE I DIDNT REALIZE HOW MANY GASKETS IN THE SET WERE WRONG, NOW THERE IS A TOTAL OF 6 WRONG GASKETS AND 2 MISSING GASKETS, AND 4 TRIPS TO THE DEALER 15 MILES ONE WAY. I ALSO KNOW "STUFF HAPPENS" JUST AS I KNOW ITS EASY TO ADAPT A CAVALIER ATTITUDE WHEN ITS SOMEONE ELSES MISFORTUNE AND DOESNT AFFECT YOU PERSONALLY SO THANKS WD FOR YOUR CAREFULLY THOUGHT OUT AND CONCISE REPLY. IF I HAD TALKED TO YOU FIRST I AM SURE ALL WOULD HAVE GONE SWIMINGLY.
