WD hydraulic pump/valve
wdTom
08-18-2004 18:49:30
I took the hydraulic pump off my WD, because it needs a couple of seals, and put on the one from the parts tractor on. I had taken this one apart and put it together with new O rings and seals. Now when the tractor is stopped and you let out the clutch it sort of doesn't want to go, and as it slows down and comes to a stop it is like a brake is on a little. It isn't the brakes. With the tractor in neutral I can easily roll it by hand. I can disengage the engine clutch and with the tractor in 4th and the handclutch engaged when I try and roll the tractor there is resistance and the sound of oil squirting under pressure in the area of the hydraulic pump. I haven't looked at adjustments as per the manual yet, that is next. Just did this change and haven't got the time yet to get into it more. Any ideas as to what is going on?? Thanks!
DS
08-18-2004 19:36:16
 Re: WD hydraulic pump/valve in reply to wdTom, 08-18-2004 18:49:30
The pump is delivering oil under pressure hence the resistance.
wdTom
08-19-2004 18:11:40
 Re: WD hydraulic pump/valve in reply to DS, 08-18-2004 19:36:16
Shouldn't there be a "unload" position where it just pumps oil to the reservoir with no load/pressure when the system isn't being used?
