WC Distributor or Magneto?
buster Padgett
08-18-2004 15:04:12
I'm helping some FFA students restore a 1939 WC. We want to restore it as original as possible. Our tractor has a working distributor, but all the reference material we've seen only talks about magnetos.
Could this tractor have had the distributor as original equipment? or do I need to find a magneto to replace it.
Thanks for the help!
Steve in N.J.
08-24-2004 20:57:23
 Re: WC Distributor or Magneto? in reply to buster Padgett, 08-18-2004 15:04:12
Buster,
On the WC, a magneto was OEM equipment. The Fairbanks Morse "K" series (FM4B) or the "J" (FMJ4B3) series Fairbanks came on the WC. Either choice would be correct for the WC in general. Both mags had a grounding lever on the side of the unit to shut the engine off. We rebuild, service, sell parts, and complete Fairbanks units if you decide to install one on the kids' project. Drop us a line if interested...
Steve/B&B Custom Circuits
[email protected]
vern(in)
08-19-2004 18:13:33
buster I have a wc mag and need your distributor. Email me if your interested in a trade
buster Padgett
08-24-2004 15:18:28
 Re: WC Distributor or Magneto? in reply to vern(in), 08-19-2004 18:13:33
Thanks for the offer, but I think I'll hang on to the distributor for awhile and work all the kinks out of the restoration with a system that the kids are familiar with. In the meantime I'll start looking for a mag to convert back with. This should prove to be very educational. Thanks again!
John (MO)
08-19-2004 07:43:17
A good working mag is hard to beat, but yes a lot have been converted to distributor ignition. Finding a mag shouldn't be that hard and working on it if necessary would be a good learning experience for you students. I can't remember if a '39 is styled or unstyled, I always think of a WC as a great looking unstyled tractor! Good luck.
buster Padgett
08-19-2004 06:39:23
Thanks for the help guys! Restoration project is for a competition so it looks like we might need to find a mag for originality.
Gene
08-18-2004 22:20:14
I recommend leaving the distributor on the tractor. Couple of reasons - (1) You don't have to spend several hundred dolars for a magneto. (2) The distributor ignition is easier to work on. (3) Parts are much cheaper for the distributor ignition than the magneto.
steve(ill)
08-18-2004 15:08:07
mag was standard till late 1950s. all WC and WD had the mag as original equipment. lots of modifications over the years.
JMS/MN
08-18-2004 22:04:58
 Re: WC Distributor or Magneto? in reply to steve(ill), 08-18-2004 15:08:07
Mag was standard on the WC, and first WDs. When the WD45 came out in '53, they came with the distributor as standard equipment. Many earlier tractors were switched over to the battery ignition with distributor because they started easier and were more dependable.
