allis c wide front
Heath Phillips
08-18-2004 14:38:24
I recently purchased an allis c with a wide front. I am wondering if it came with a wide front, was that an option or did the c only come as a tricycle? . Paid $1000 for it. Was that a good deal? All the metal is straight, new tires on the rear and fronts can't be more than a year or two old. Runs great, took 4th place in a pull less than a week after I got it. Thank you.
Herb Brady
08-20-2004 15:28:22
 Re: allis c wide front in reply to Heath Phillips, 08-18-2004 14:38:24
Heath The wide front on a C is a lot differn;t than on a B. The front end on a C has a gear box in front and steers out to each front wheel from the center. The B steers up to the left front and then across to the other wheel. According to Norm swinfords allis book they only built a little over 5000 Cs with a wide front and only offered them the last 4 years.
MAD DUC
08-19-2004 07:03:03
A 4th place?? Must be running NOS or somebody sure gave it a good tune-up! HA HA HA. Sounds like it as been changed.
Greg Ballantyne
08-18-2004 18:03:14
LIke Steve says, I've seen a few tractors for sale that are B's from the transmission/torque tube forward and C or CA's to the rear. They all have the B wishbone front axle.
steve(ill)
08-18-2004 15:12:57
adjustable wide front end was an option. if you hav a cast wishbone alxe, it came off a B.. the original "optional" wide front for the C was adjustable beam design. you r steering arm on the gear box under gas tank should point straight up. your steering rod should go to a bevel gear box below the radiator and tie onto the short arm at that point.---- if the rod goes to the front left wheel king pin, it has been modified.
WR
08-18-2004 21:47:14
 Re: allis c wide front in reply to steve(ill), 08-18-2004 15:12:57
steve
Do you have a photo of the center pivot pin showing how it's welded to the adj wide front?
steve(ill)
08-19-2004 16:12:51
 Re: allis c wide front in reply to WR, 08-18-2004 21:47:14
on the "B" there is a center horizontal pivot pin. THe C was designed as a narrow front end with the 90 degree gear box mounted in front of the radiator. center vertical shaft connected to the wheels sets in upper and lower bearings. when you get a wide front they use the same basic gear box and mount a vertical shaft onto the box axle. odd looking setup.---- if you mount a B front end on a C, you use the B mounting block with the 7/8 inch pivot pin in the center of the axle (horizontal). i dont have a photo, but might be able to copy the service manual picture if i cna find it. send me a note. [email protected]
