WD clutch adjustment problem
Kevin Kostiuk
08-18-2004 04:24:10
I just replaced the clutch in my WD and can't get it to adjust up enough to work. The rod for the pedal is adjusted all the way to the end of the threads and the bolts on the pressure plate are adjusted in (to move the fingers as close to the throw out bearing as possible) as far as they can go but I still have no clutch. Is it possible I got the wrong clutch? Is something bent? The old clutch although covered in oil had the same problem but it did work some. Thanks for any help.
Burgie
09-09-2004 16:08:41
 Re: WD clutch adjustment problem in reply to Kevin Kostiuk, 08-18-2004 04:24:10
Have you checked the set screw in the throw-out bearing fork??
Tramway Guy
08-18-2004 19:50:10
Maybe the clutch disc is backwards..they are usually not symmetrical, putting it in with the wrong side out could cause it to stand away from the flywheel....maybe.
Kevin Kostiuk
08-19-2004 14:34:23
 WD clutch adjustment problem in reply to Tramway Guy, 08-18-2004 19:50:10
I was actually wondering that. One side of the spline hole stands out from the disc and the other side is either flush or below. I installed it with the sticking out part towards the throw out bearing. Is that correct?
Kevin Kostiuk
08-18-2004 19:14:25
The problem has to be with the shift lever, shift fork, or the clutch. I put some longer bolts in the release lever to get the fingers closer to the throw out bearing and it still doesn't work. I'm thinking I've either got the wrong clutch or it's bad or something is bent.
wdTom
08-18-2004 18:41:03
Do you have too much "free play"? All you need is an inch or so. Maybe the linkate is worn and you are not getting enough travel.
