#1 piston ? on ca
jontl
08-16-2004 06:08:39
From the fan, which is the #1 piston? From what I know from the fan it is 2134
And on the distributor which is the #1 and does it go counter clockwise looking down at the cap?
Jim Danforth
08-16-2004 19:22:42
 Re: #1 piston ? on ca in reply to jontl, 08-16-2004 06:08:39
The worst part is trying to blink your ear fast enough to see the timing marks! But my tounge get sore holding it on the coil wire!
JimD
DanD.
08-16-2004 17:13:34
The piston closest to the radiator is #1, then comes 2, 3 and 4 at the rear. The firing order is 1243. Depending how the previous mechanic installed the distributor, any position on the distributor can be made #1, but usually it's the one farthest ahead and closest to the block. To be sure, remove all spark plugs, turn the engine over slowly while holding your thumb over #1 spark plug hole. When you feel air being forced out around your thumb, you know that #1 is getting ready to fire. Pop off your distributor cap and look where the rotor is pointing. That will be #1 on the distributor. Hook that wire up to #1 spark plug. The distributor turns clockwise so hook the next hole on the distributor to #2 cylinder, then to #4, then to #3.
Lil-Farmer
08-16-2004 18:50:49
 Re: #1 piston ? on ca in reply to Jim Danforth, 08-16-2004 06:57:05
I tried timing by "ear" once..... made 'em sore, so I quit. (-:
Couldn't help it, Jim.
