WD Question:Exhaust manifold studs and gaskets
Pat Cruise
08-15-2004 14:43:21
Where can I get a new set of manifold studs for a 1950 WD and should I install the gaskets with a high temp sealer of just leave them dry?
Thank You to all you devoted AC fans.
Pat Cruise in Kansas
Gene
08-15-2004 17:22:23
 Re: WD Question:Exhaust manifold studs and gaskets in reply to Pat Cruise, 08-15-2004 14:43:21
Hardware store, grade 8 bolts. Put some non-hardening sealent on the threads of each bolt.
I couldn't find studs the correct size and lenght locally. One of the parts store guys, also a WD owner, told me about using bolts. They work great.
Manifold gaskets go on dry.
bw in mo
08-15-2004 17:29:05
 Re: WD Question:Exhaust manifold studs and gaskets in reply to Gene, 08-15-2004 17:22:23
I get mine from the AGCO dealer, there not that expensive. use high temp antisease.is all that is nesecery for a sealer on the threads.
bw in mo
