Trouble getting CA started HELP
Jontl
08-15-2004 13:18:34
I have changed plugs and wires, fresh gas, cleaned carburator, new cables, getting spark at each plug and it won't start. I get a pop every few revolutions but won't start. Adjusted carburator each direction from the 1-1/2 turn starting spot.
Steve in N.J.
08-17-2004 15:18:56
 Re: Trouble getting CA started HELP in reply to Jontl, 08-15-2004 13:18:34
If you have spark, and you have fuel, (wet plugs) it should start. Sounds like the timing is off. Jimmy's right. Loose the Chimpanze spark plugs and put in a real set of plugs-Autolite 295's or 303's as mentioned. Either will work with a distributor. Set it up on TDC, do the firing order on the cap, and it should come to life providing there isn't any stuck valves..... Steve/B&B Custom Circuits
jontl
08-17-2004 18:16:17
 Steve in NJ in reply to Steve in N.J., 08-17-2004 15:18:56
Why would I want to go to a colder plug(303) when the 295 is the cross reference to the j8c?
I had to remove the sickle mower so that I could see the timing hole, so now I should have it timed right, it is just kind of funny that it would start before not the easiest but it started. The battery was low and tired of cranking on it, but it is popping easier with cranking, time ran out tonight hopefully tommorow night she will be purring. Thanks, in advance.
Jon
Nellie
08-15-2004 17:06:24
I have this happen on my D17. I swore the wires to the plugs were right. They weren't. My CA will start with just two plugs. Try just connecting 1 and 4. Keep moving the wires around at the distributer. Make sure the points are clean and there is not a spot of crud on the points. One long shot, the wire from the coil to the distributor could have a small short where it goes throught the distributor. This would cause intermitten spark, and no start. Check to see if that insulator through the distributor is not cracked.
If you get a pop you are so very close to have it running. Good Luck, sorry you had to hear about the firing order again.
jontl
08-15-2004 16:16:39
 Re: Trouble getting CA started HELP in reply to Jim Danforth, 08-15-2004 14:59:05
Yes it ran before, last summer, firing order is 1243, yes with a starter, no I have not tried pulling yet, and the plugs are j8c
Russ
08-15-2004 14:58:48
Allis CA; Do you know what the Fire Order on your CA is? From the number one cylinder is the wiring set up per the Fire Order? When was the last time your rig was running? What was tore down and put back together since that time?
cmarlin66
08-15-2004 14:00:06
are you using wire plugwires or graphite
graphite wires on a mag will not work
jontl
08-15-2004 14:07:23
 Re: Trouble getting CA started HELP in reply to cmarlin66, 08-15-2004 14:00:06
Yes they are copper core, and it is a distribuor.
cmarlin66
08-15-2004 14:26:35
 Re: Trouble getting CA started HELP in reply to jontl, 08-15-2004 14:07:23
do you have a working starter if so
try using a triger sprayer (like a window cleaner)
to spray fuel in the carb. while tying to start with starter
jontl
08-15-2004 14:57:30
 Re: Trouble getting CA started HELP in reply to cmarlin66, 08-15-2004 14:26:35
I will try that, the spark plugs are wet, I don"t think it is flooded though.
