allis c or ca help
havvey
08-09-2004 16:57:04
would you guru's tell me the difference i have to look at one soon i think they are a sweet little tractor any problems to look at in particular?
havvey
08-10-2004 03:27:51
 Re: allis c or ca help in reply to havvey, 08-09-2004 16:57:04
so does the c have a 3 speed? is there much difference in the engine output?
JMS/MN
08-10-2004 09:28:23
 Re: allis c or ca help in reply to havvey, 08-10-2004 03:27:51
Model C has a 3 speed tranny, CA is a 4 speed, and has Power Shift rear wheels. Slightly better hydraulics, and the possibility of a Snap-Coupler hitch for mounted implements. Bit more power from basically the same engine.
JF
08-09-2004 18:43:06
I have a ca and love it.
Going to get another one.
wdTom
08-09-2004 17:56:45
CAs will have 4 speeds, possibly a clutch in the right rear axle housing, will say CA in the serial no. which is by the shift lever. C will say C and then the number. CAs had the final drives angled slightly backward making the wheelbase longer, Cs finals were directly under the axle housing. CAs had power shift rear wheels, Cs did not. By now, 50 years later tractors can be made up of parts from several different tractors. Have one with a C rear end and transmission, B front with a B wide adjustable front axle. Why, needed third gear and the whole rear end and transmission was cheaper than two new gears and the parts tractor parts had foot brakes too, original B did not. Then swapped out the engine for a newer one from a later B. Tractor has parts from 3 different ones. I expect that by now there are many like this. You never know what you will find. Check the engine no. too.
Dana (Iowa)
08-09-2004 17:44:40
Here's a link to a nice site that has some great photos of AC tractors. If you look at the C pics, the 2nd and 3rd photos are of my Model C (before and after restoration).
