Stuck in 1st
New AC Guy
08-09-2004 08:52:51
AC Friends: I have a 1957 D-17 that is stuck in 1st gear,I have a service manual and it says before you remove the cover plate it must be in neutal,but I can't get it in neutal.This is the first time this has ever happen,and this is my first tractor.What can I do to fix so I can use it again.[pictures or any other help]Thanks
Jed
08-09-2004 12:13:43
 Re: Stuck in 1st in reply to New AC Guy , 08-09-2004 08:52:51
I am going to go out on a limb here because I don't really know about a D17. If however it has a pin that goes through the stick housing, you may have an easy fix. On the older AC tractors such as the WD, you can simply knock out the pin that holds the shifter in the housing neck. This may have an end cap on it that you will need to remove. Next lift out the shifter and look down in to the rails. take a long screw driver and realign the rails to neutral. They will line up and you will know. The tip of the shifter wears off and it won't stay in the rail while you complete the shift and therefore it becomes stuck in the gear you just left and the one you were going to. Good luck.
