Double Groove Crankshaft Pulley
Joe
08-06-2004 20:52:27
Hey guys, I was wondering if anyone can find a source for a double-groove crankshaft pulley for a wd. Our local AGCO dealer cant seem to find one. We are installing a char-lynn power steering unit on a wd with narrow front wheels. I looked at some of these older posts and saw info on Wellerts, but can't find them on the internet or phone book. Any help sure would be great. Also - could I just weld a same size pulley to the front of my single groove that is already on this wd ? Thanks for your help !
JMS/MN
08-06-2004 22:36:19
 Re: Double Groove Crankshaft Pulley in reply to Joe, 08-06-2004 20:52:27
AC used to provide a double groove pulley which was used to drive the factory power steering pump. You might find one in a salvage yard. If you weld an additional sheave on an existing pulley you need to true it up in a lathe. There are other options to put a front mount pump on the tractor.
Tony C
08-07-2004 16:40:48
 Re: Double Groove Crankshaft Pulley in reply to JMS/MN, 08-06-2004 22:36:19
We have double pulley available. Check with Kim first . Tony
Joe -- Tony C.
08-08-2004 06:22:14
 Re: Double Groove Crankshaft Pulley in reply to Tony C, 08-07-2004 16:40:48
Tony - Thanks for the response on the double groove crankshaft. Our WD is gas and narrow front. Please let me know if your double groove will fit. I also need to know how to contact you. Thanks, Joe
Joe
08-08-2004 06:11:29
If you have one - double groove how do I contact you. My number is 920-623-4551. Thanks Joe.
Tony C
08-08-2004 15:18:59
 Re: Double Groove Crankshaft Pulley in reply to Joe, 08-08-2004 06:11:29
Joe just clik on my email. I also called you and left a message. Tony
