WD 45, Starter sparks
GT
08-06-2004 10:11:50
WD 45, When trying to start it, I get sparks only.
Have rebuilt starter installed, but same thing.
Acts like a short, but where to check?
Dave (NE)
08-06-2004 13:10:38
 Re: WD 45, Starter sparks in reply to GT, 08-06-2004 10:11:50
Are the sparks coming from the starter or from the battery area? I've had sparks from the battery connection, which indicated that the cable was bad. I cut off the end, installed a new one to the battery and it solved the problem, so maybe you have a cable problem. Dave
GT
08-06-2004 13:20:04
 Re: WD 45, Starter sparks in reply to Dave (NE), 08-06-2004 13:10:38
The sparks come from the terminal on the outside of the starter case. The point where the connection is made.
AC
08-06-2004 19:38:31
 Re: WD 45, Starter sparks in reply to GT, 08-06-2004 13:20:04
Be sure that the terminal end is not touching the frame of the switch on top of the starter. There is supposed to be an insulator(thin fiber disc) at the bottom of the stud. If required, remove the switch from the starter and ensure the "insides" are not rubbing the switch frame either. A rebuilt starter "shouldn't" be sparking.
cmarlin66
08-09-2004 12:34:30
 Re: WD 45, Starter sparks in reply to AC, 08-06-2004 19:38:31
sometimes when tighting the starter terminal to the battery cable the terminal will slip a little and cause them to "short" inside even on a new reman starter
