WD wide front - 3 bolt vs. 4 bolt
Rock_Picker
08-05-2004 20:59:50
Would someone explain the difference between a 3-bolt and a 4-bolt type wide front for a WD or WD-45? A 4-bolt type is considerably more expensive at the salvage yards..... ..... .RP
John (C-IL)
08-06-2004 07:34:31
 Re: WD wide front - 3 bolt vs. 4 bolt in reply to Rock_Picker, 08-05-2004 20:59:50
Engineering wise the 4 bolt is better because the load is spread out over a wider (for lack of a better term) area on the bolster. I have seen 2 of the 3 bolt fronts that had broken out the front of the bolster. My guess is that it was because of the additional weight of a front end loader or some hot rodder popping wheelies, of course I wouldn't know anyone that would do that.
Dave Grubb
08-06-2004 06:09:28
The 3 bolt unit was the original style. As I recall the 4 bolt unit came out on the WD45 tractors to handle the additional weight of the diesel engine equipped tractors.
wdTom
08-06-2004 18:35:22
 Re: WD wide front - 3 bolt vs. 4 bolt in reply to Dave Grubb, 08-06-2004 06:09:28
Would the 4 bolt one be the one that you can bolt up different wheel types (single front, or dual trycycle) to? Or the arm that connects to the tie rods for a wide front? Later tractors had this feature but I don't knowwhen it started.
