Second thoughts. Pull belts from all of the belt driven equipment on the front of the engine; water pump, alternator/generator, etc.. My revised first thought is that the water pump gave out. Usually leaks, but the impeller may be grinding on the block or water pump casting causing the screech. Grab the fan and shove it into the engine and turn, then pull out and turn. If you can feel any grinding it needs to be replaced. Drain out the antifreeze, replace with plain water. Let set for a while. Check for external leaks. No external leaks, wait 24 hours and check the water level again. If the water level drops you have a crack somewhere in the head or block. If the water pump is bad I would check for resistance via my first suggestion, turn the engine over by hand with the spark plugs out. No unusual resistance, replace the water pump and give the engine another try. No unusual resistance when turning the engine over by hand. Leave the spark plugs out and use the starter to crank the engine or 20 or 30 seconds. Check the oil pressure gauge while cranking. You want to see the oil pressure gauge needle move up - good sign - the engine didn't loose oil pressure. I'm surprised someone else hasn't jumped in with suggestions on this problem.
