WD Transmission
Jeff W
08-04-2004 12:52:35
I am getting ready to change the tansmission fulid on my WD and I am having trouble finding the two fill plugs. I bought the manual and it shows the plugs on the LH side of the tractor by the hydralic fill, the only plug I can find is on the RH side of the tracor near the starter. Any help would be appreciated. Thank you.
Bryan g in mo
08-04-2004 14:50:22
 Re: WD Transmission in reply to Jeff W, 08-04-2004 12:52:35
If you found the hydralic fill plug, the transmission fill plug is to the rear of the tractor and just a little lower on the case , should be a square headed pipe plug, there also will be two different plugs , same area.
Jeff W
08-05-2004 14:29:24
 Re: WD Transmission in reply to Bryan g in mo, 08-04-2004 14:50:22
Thanks, I did find both of the plugs. They look like a real challange to get a wrench on. I will have to try a couple of things
Dave K
08-07-2004 09:38:56
 Re: WD Transmission in reply to Jeff W, 08-05-2004 14:29:24
I get to those plugs with a socket and extender bar. 5 or 8 sided socket works best for me.
Dave
Guyzoo
08-07-2004 17:40:29
 Re: WD Transmission in reply to Dave K, 08-07-2004 09:38:56
You can remove them with an extender bar and sockets. one is 3/4 and the other is 1". HTH
