side curtains
bleeding orange
08-04-2004 08:03:28
I recently found a 37 WC with engine side curtains.They look like original equipment,but I have never seen anything like them before. They look alot like the old Oliver ones. Does anyone know if these could have been a factory option or if they are likely add ons.
JMS/MN
08-04-2004 08:42:21
 Re: side curtains in reply to bleeding orange, 08-04-2004 08:03:28
The mounted picker came with side curtains that were used to keep corn leaves and trash from getting to the engine. They had vents in the side to allow for air movement, and a slide panel you raised to check the oil. Is that the type that's on your tractor? There was also a different cap for the air cleaner- it had a screen on it to keep trash out.
bleeding orange
08-04-2004 13:06:27
 Re: side curtains in reply to JMS/MN, 08-04-2004 08:42:21
This sounds exactly like what I have. Thank you for the information. Now it makes sense.
JMS/MN
08-04-2004 16:51:21
 Re: side curtains in reply to bleeding orange, 08-04-2004 13:06:27
I wasn't sure if they would fit the unstyled WC, although we had them on the '47 WC when I was growing up. We had a '39 and '47 in those years, and Dad built a wood/masonite cab, with the windshield from his Dad's '37 Chrysler, to make winter manure hauling a bit easier. Otherwise- they were just used on the corn picker, until I built some side frames to fit the WD45, from the gas tank to the rear, for winter hauling- and used the picker panels to cover the engine. Brought the heat back on the cold days!
