Allis B Engine
Jeff In Ontario
08-02-2004 21:16:09
Hi fella's. I posted here the other day about this 1941 Allis B that I just purchased. Well, today I took the head off to see why it is stuck, and 3 pistons are clean & free, but one (closest to the driver) is totally rusted solid. Luckily, I don't see any cracks in the block at all, but i noticed some antifreeze in on the pistons, and in the holes where the bolts hold the head to the block. Not being a mechanic, is this normal?? If not, what should I be looking for? Also, any advice as to how to free up this stuck piston would be appreciated!! Thanks !---Jeff
Dick L
08-03-2004 06:43:52
 Re: Allis B Engine in reply to Jeff In Ontario, 08-02-2004 21:16:09
Being just me, my advise would be to punch the sleeve, piston, and rod out the top. In a hydraulic press, press the piston out the bottom of the sleeve. If it turns you can save any thing good on you but if you find the piston and sleeve pitted deep you are ready to put in a new or used piston and sleeve with in hours not weeks. If it is only one assembly you are lucky beacuse most of the time it will be two holes that have valves open to let exaust manifold leaking water in.
