WD 45 Hand Clutch
JKH
08-01-2004 06:36:22
Hello Everyone I need to park my 1955 WD 45 for an extended time. 6 Months to 1 Year. Should I leave the hand clutch ( Forward disengaged ) or ( Back engaged ). Thank You for any help.
Dan Feist
08-11-2004 21:03:50
 Re: WD 45 Hand Clutch in reply to JKH, 08-01-2004 06:36:22
Where can I get a hand clutch for a WD45 and installation directions?
rrhead(SD)
08-01-2004 07:57:02
I was always told to leave the hand clutch on a WD engaged and to leave it disengaged on a D series. Don't know why, just what I've heard. rrhead(SD)
Sid
08-01-2004 07:41:12
For what it is worth I probably would leave it disengaged. If you are not already aware there is a clutch lock that will lock the engine clutch and keep it disengaged. Personaley I would prefer to leave this clutch engaged rather than store it with pressure on the clutch springs. I checked my owners manual and there is no mention of this in the section on storing the tractor for a period of time. So I guess it boils down to what ever you feel is the best for your tractor.
Sid
08-01-2004 17:23:07
 Re: WD 45 Hand Clutch in reply to redcub, 08-01-2004 14:31:05
Behind the foot clutch inside the chassis rail is a piece about 6-7 inches long that will pivot toward the front. If you push the foot clutch in and rotate this piece foward it has a notch that will hold the foot clutch foward. This would be used to stop the belt pulley when you were useing it to power belt driven equipment such as a threshing machine.
Roger
08-01-2004 22:50:31
 Re: WD 45 Hand Clutch in reply to Sid, 08-01-2004 17:23:07
also a good safety to lock clutch when hand cranking to start
