AC C transfer case smokes
L-Train
07-30-2004 19:40:30
Just aquired a 1948 C. It seemed to run fine at pick-up. It got a little warm when I attempted to use the 60" belly mower. Now I noticed after running for a minute or two that smoke comes from the tranfer case & I think it is starting to knock. I can see bare metal in the tranfer case, is this normal? Oil & hyd. levels seam fine. Is this just a radiator/thermostat problem or something more serious? Any help would be greatly appreciated.
DanD.
07-31-2004 05:49:46
 Re: AC C transfer case smokes in reply to L-Train, 07-30-2004 19:40:30
What exactly do you mean by the transfer case? On a C, you have the engine, transmission, differential, and PTO.
L-Train
08-04-2004 06:06:32
 Re: AC C transfer case smokes in reply to DanD., 07-31-2004 05:49:46
Better terminology might be clutch housing? I can see the flywheel and smoke comes from this hole after only a minute or two. At starting the engine sounds fine then starts to screach shortly after. Does this sound like a lubricating problem or could bad gas be the culprite?
I am going to drain the gas tonight, normal unleaded gas should work fine right? Avoid ethenal?
DanD.
08-04-2004 17:08:43
 Re: AC C transfer case smokes in reply to L-Train, 08-04-2004 06:06:32
Could be the clutch slipping if the smoke is coming from the clutch housing.
