WD quits
Peter
07-29-2004 20:09:06
Hi, I am experiencing a very frustrating occurrance with my 50 WD. It is mag fired and has a MS carb. It will start ok and run for 1/2 to 1 hour then start to run really rough and quit. At this point it will not start although sometimes it will start again in a few hours. The points, condensor & wires are new, the plugs are not old and are Champions. The carb had a kit in it last summer. Could this be a coil? or is the mag getting tired? Thanks Peter
Gene
07-29-2004 22:42:54
 Re: WD quits in reply to Peter, 07-29-2004 20:09:06
My guess it is either the condensor or magneto coil breaking down when hot. Next time it quits, pull one spark plug wire and see if there is spark. No spark, it's an ignition problem.
JMS/MN
07-31-2004 10:47:45
 Re: WD quits in reply to Gene, 07-29-2004 22:42:54
My first guess is-I agree with you. If it is electrical- if often dies right now! Fuel problem is usually sputtering before they die out. Oftentimes, when poor coils warm up, they give up and quit. Sometimes, even new ones are bad.
JMS/MN
07-31-2004 10:53:29
 Re: WD quits in reply to JMS/MN, 07-31-2004 10:47:45
Just re-read your post. First, get rid of the Champion spark plugs, go to Autolite. Also, if it is a magneto ignition, quits, restarts after cooling down, the magneto is likely to need a rebuild. Especially if a pullstart will start the tractor, before cooling down. Had two tractors like that many years ago. Beyond that, go with my post above.
cmarlin66
07-31-2004 15:21:18
 Re: WD quits in reply to JMS/MN, 07-31-2004 10:53:29
no frost on intake?
normally if it is ingnition trouble it will not run rough then die it will just die
check air/fuel flow maybe above carb. or valves sticky
Peter
07-31-2004 20:09:08
 Re: WD quits in reply to cmarlin66, 07-31-2004 15:21:18
Thanks for the info, I tried this spring to get AC plugs but when I ordered my tune up kit the guy at the store forgot the plugs, will try again. I took out the coil so when I order a replacement it will be correct. When I had the mag apart I noticed that there are spots for two 'pins' that hold back the impulse coupling. This mag has only one, the other looks like its been out for a long time. Is this normal or should there be two. Also what holds the rotor in place in the mag? Peter
