Possible Combine Motor
Matt Brunk
07-29-2004 18:25:15
Did allis chalmers ever put any combine motors in early wd45's? My 1953 wd45 has a canister oil filter higher up on the block and it cannot be changed to the screw on type.There is no wd45 motor stamp either.The only identification I found was the casting number 100-174.
JMS/MN
07-31-2004 10:58:25
 Re: Possible Combine Motor in reply to Matt Brunk, 07-29-2004 18:25:15
It went the other way around- the Model 100 combine used the WD45 motor. I'd go with the other guys-someone switched the original motor.
Lester
07-30-2004 10:53:22
This is not an original WD45 engine and was not installed at the AC factory when the tractor was built. It might very well be some sort of stationary engine that was installed by a previous owner.
Don Dittmar
07-30-2004 05:50:17
I dont think AC put combine engine is the tractor, but they may have changed the engine some and put it in a combine. It is also possible that some did an engine swap long ago.
Guyzoo
07-29-2004 19:11:31
If it is a WD-45 motor the serial number will start by 45 and it is located near the hose that connect to the air cleaner and carburetor
Matt Brunk
07-29-2004 19:15:05
 Re: Possible Combine Motor in reply to Guyzoo, 07-29-2004 19:11:31
There is no number on that side. The block is blank on that side.
CHALMERSBOB
07-30-2004 20:34:40
 Re: Possible Combine Motor in reply to Matt Brunk, 07-29-2004 19:15:05
POSSIBLY A LEROI ENGINE WHICH USED A ALLIS BLOCK. BOB
