Allis B running rough?
TractorMike
07-26-2004 16:49:38
Hi all, For the past couple of weeks I have been trying to get my Allis B running right. I have it running pretty much the way I want it but after it warms up to about the 170( give or take 20) deg it starts ruinning REALLY REALLY rough. And I can't figger it out, It has new points, new condencer, New spark plugs, New coil, And good fuel flow. The only thing it dosen't have is new spark plug wires, Or a carb rebuild( which I really dont think it needs) Or batery cables. That's about all I can think of. So and advice would be Appreciated. Thanks, TractorMike
cmarlin66
08-09-2004 16:00:08
 Re: Allis B running rough? in reply to TractorMike, 07-26-2004 16:49:38
if it pops out the exhaust it could be exh. valves
if it pops out the carb it could be intake valves
not bad but sticky
Steve in N.J.
07-28-2004 19:19:21
Mike,
Mag fired or distributor? BTW- We have wire sets for either if ya think ya need em'....
Steve@B&B
TractorMike
08-05-2004 18:39:06
 Re: Re: Allis B running rough? in reply to Steve in N.J., 07-28-2004 19:19:21
Steve, It is mag fired. I'll let you know if I need a wire set. Thanks, TractorMike
Jeff In Ontario
07-26-2004 17:10:48
Mike: Almost always this is a symptom of a bad coil, if it's new then maybe it's defective, but that is the only thing i can think of. Hope this helps! ---Jeff
