D 14 2 POINT
TOM
07-26-2004 05:34:26
IS THERE ANY WAY TO MAKE THE 2 POINT HITCH ON MY D 14 WORK TO MOUNT A REAR MOUNT FINISH MOWER? ARE THERE ANY KITS AVAILABLE TO DO THIS?
George
07-27-2004 09:21:30
 Re: D 14 2 POINT in reply to TOM, 07-26-2004 05:34:26
I must not be able to count: snap coupler, left lift arm, right lift arm: one, two, three...
Standard 3 point: left lift arm, right lift arm, top link: one, two, three...
International 2 point: left lift arm, right lift arm: one two...
I understand propriority systems and patents and such as well as most. I also know that not always does the best designed of something become the most common.
Convert the AC snap coupler or pin hitch to the standard 3 point configuration if you need to, in order that you can use equipment of that design. But do so knowing that the AC snap coupler and traction booster systems are superior in traction, lift and control of implements to the now standard 3 point hitch.
Don Dittmar
07-26-2004 08:55:42
Tom,
There are 3pt conversion kits avaliable to convert the two point to the three point. They usually sell from 350-500 dollars. Try www.tonystractors.com.
