hard starting wc
larry
07-25-2004 09:08:19
I am in the process of restoring a 37 WC .I have rebuilt the motor and had it running,the problem is I can't get it started by cranking it by hand.To get it started I use another tractor with a belt.The mag has new points& condensor,new plug wires.Is it possible the coil is a little weak & when I use the belt I have enough RPM's to get it going?Getting frustrated, thinking about switching to electronic ignition.Any input would be appreciated!
acorange
07-26-2004 16:20:19
 Re: hard starting wc in reply to larry, 07-25-2004 09:08:19
Keep it original. A properly set up WC should
start easily with the crank.
Heck, my grandmother started one by hand quite often in the 30's and 40's along with a W-40
Mcormick-Deering.
Try getting a yuppie housewife to do that today!
JMS/MN
07-25-2004 23:40:16
Keep it original, skip the electronic stuff. Was at the Orange Spectacular in Hutchinson today, watched one guy start his '37. Took 8-10 lazy pull-ups on the crank and it popped off. Check the impulse and the coil- it should do the same.
Robert
07-25-2004 21:26:42
how long since rebuild?could thing just not be broke in good yet?? i had a wd that was that way! but after puting a good load to her and getting her broke in she started fine with the hand crank!
DanD.
07-25-2004 13:23:18
Is the impulse working on the magneto? It should make a definite snap on each compression stroke when you turn it by hand. If it's not working, it will not start with the hand crank.
larry
07-25-2004 19:09:05
 Re: Re: hard starting wc in reply to DanD., 07-25-2004 13:23:18
the impluse is working,I have gotten it started on two different occasions with the crank.thank's for the reply.
