Allis B Steering Assy
jack m
07-25-2004 06:28:42
Anyone know if the steering assembly (shaft & box) from an 1940 electric start C will go directly in a 39 crank start B?
thanks,
jack m
jack m
07-30-2004 03:53:45
 Re: Allis B Steering Assy in reply to jack m, 07-25-2004 06:28:42
Thanks for the responses and information, gentlemen, I'll surely post the information gained in my ministrations.
mark carlson
07-25-2004 20:26:10
Yes it will
steve
07-25-2004 18:44:01
i agree with Jim, the B and C boxes are "left " hand and "right" hand gears inside. THe C arm sticks UP the B arm sticks DOWN. should steer backward putting the C on the B, unless you have the C arm and point it straigth up and run the rod catty wompus to the front wheel.
Rick
07-25-2004 13:26:58
Jack, Yes,if it's a Ross steering box and steering shaft,I know it'll work fine. The thing is,you'll have to make sure you use the steering arm off the B. Hope this helps. Thanks,Rick
zac
07-25-2004 09:39:59
We did it,It worked on mine just fine.
