So I bought a C. Questions, questions, questions.
Ryan
07-25-2004 05:40:55
I just bought a C that came with the dual plow setup. Well, I had to see those plows on it but after putting them on I noticed that the hydraulics are a tad on the leaky side. It looks like both the valve and the cylinders will need to be gone over. Will my agco dealer still have these parts? If not, who will?
Where should the positive ground be attached to? Currently mine goes back to the rear of the tractor and fastens on the left seat mount. Is that right?
The spring which holds the clutch pedal from flipping backwards is broke. For the life of me I can not seem to figure out where that was to attach.
I am planning on doing a compression test. What should the numbers be around?
I noticed that this tractor has the weights mounted on the side of the engine. How much do they weigh each?
The boot around the base of the shifter is cracked. Is this still an obtainable part?
Finally, does the plow have its own mounting or is that standard for the C's? I also noticed that there are 2 draft controls. One on each side. However, nothing appears to hookup the the left one. Is somethign missing?
Thanks for any and all help.
Gene
07-26-2004 08:20:03
 Re: So I bought a C. Questions, questions, questi in reply to Ryan, 07-25-2004 05:40:55
Some answers:
Purchase the IT manual, also a parts and an operators manual for the tractor. AGCO will have the parts including the boot or the advertisers on this web site.
Compression should be even on all cylinders + or - 10 PSI. 90 PSI or above would be nice.
Weights. I don't know, could be any amount.
