190XT hydraulics check
Richard
07-24-2004 22:12:44
Could someone PLEASE tell me where to check the hydraulic oil on a 190 XT Series III diesel, Thanks in advance.
Merle
07-25-2004 04:04:55
 Re: 190XT hydraulics check in reply to Richard, 07-24-2004 22:12:44
Richard
As you are sitting on the seat look strait down. On the right side is the dip stick/add point for the tranny. On the left side you will see about a 1 1/8" hex head, remove that hex and that is where the hyd oil check/add point is. make sure you clean around it first as dirt likes to fall in when you remove it. You might also have to remove a plate that sits right on top of all this. Not one of Allis's better designs. Also if you have a seal bad in the system the hyd fluid will all collect in the trany side of the side of rear end and leave the hyd system empty. An interm fix for this problem till you can fix the seal. Is to connect both drain's with a drain line. If you have this problem email me and I'll send pictures of how I did mine. If you do this be carfull not to over fill one of the resevors. one will always be at the top of the full line and the other at the low mark. Overfilling will allow oil to get in the brakes and that opens up another can of worms.
Good luck
Merle
Scott(nc)
08-29-2004 16:15:55
 Re: Re: 190XT hydraulics check in reply to Merle, 07-25-2004 04:04:55
can you email me the pic. of your interm fix for the problem of the trans and hyd over filling thanks scott
