Overheating D14 and D15
Glenn Weatherfo
05-20-1999 19:32:02
We have a D14 and D15. Both overheat under tillage loads (plowing or disking, etc.). One has been "boiled out" and the other has a new radiator core, but they continue to overheat or boil. I'd appreciate any ideas about how to eliminate the problem. Thanks
steve webb
07-30-1999 20:14:09
 Re: Overheating D14 and D15 in reply to Glenn Weatherford, 05-20-1999 19:32:02
looking for a power steering pump for a gasoline 14 or 15 allis chalmers tractor, used or new
Chuck
05-21-1999 20:31:23
I know this is almost too simple, but check your fan belt tension first. My AC D-12 started heating up under load this season and when I checked the belt it seemed tight enough. However, I tightened it a lttle more and my overheating problem cleared up.
orangeman
05-21-1999 09:22:15
With new radiators, the problem is either stuck thermostats or clogged water jackets in the blocks. My money is on the thermostats. I have run D-series without thermostats.even though they are designed to run at a higher temperature it's better than overheating but probably isn't a good idea over the long run.
Jim
05-21-1999 10:58:16
 Re: Re: Overheating D14 and D15 in reply to orangeman, 05-21-1999 09:22:15
You should run thermostat keep the engine temp. up. I've seen tractors run hot without a thermostat because the coolant don't have time to cool when the coolant goes threw the radator to fast.
