D-17 rims?
Joe
07-22-2004 18:48:14
My friend has a d-17 wide front . He wants to put wider tires on front. Does anyone make rims for this ? I believe they are 5 bolt 3 inches on center, 16 inch .. I am new to site but want to thank you all in advance .
TexasAllis
07-23-2004 13:18:02
 Re: D-17 rims? in reply to Joe, 07-22-2004 18:48:14
I have 15X7 on my D-17 to run 10 ply truck tires. The rims are Dodge truck. They have a larger center hole than most standard rims. Not too difficult to find.
Kevin (FL)
07-23-2004 07:44:19
Joe,
We bought a D17 diesel that has "balloon" tires on it. The rims have welded sections to make them wider. We were thinking about getting original sized rims because we don't need the wide ones. The tractor originally had a street sweeper on it so that's why they put the wide tires on it. Where are you located? Maybe we can work out a swap?? The tires we have hold air fine but one of them has a cut through the tread. They look like airplane tires or what you would see on a large farm trailer.
JMS/MN
07-22-2004 23:23:29
The first D17 I had, Series One, I found wider rims for it, with the right bolt pattern- I think they were off a Buick from about the same era.
Wally G.
07-24-2004 21:42:52
 Re: Re: D-17 rims? in reply to JMS/MN, 07-22-2004 23:23:29
Your right, they were from old Buicks. Got some 15" wheels for the AC's and ran car tires on them.
Joe
07-24-2004 19:10:05
Thanks for the info! I knew old tractor lovers would come through .. thanks again and see you at an old iron show somewhere .. Joe
